2026-07-08 06:15:41
1.2k
164
Mandalorian Razor Crest Star Wars Replica
@dharian_5531540
"This is the Way." — Track down your next bounty and add the galaxy's favorite gunship to your fleet!
This is a highly detailed, 3D-printable scale model of the ST-70 assault gunship, better known as the Razor Crest from The Mandalorian. Before its tragic run-in with a cruiser's turbolaser, this pre-Empire military patrol craft was the rugged home to Din Djarin and Grogu. This model perfectly captures its blocky, industrial design, massive twin hull-mounted engines, and signature rear boarding ramp lines.
This version has been specifically engineered for single-color printing. You don’t need an AMS, MMU, or complex multi-material setups to make it look spectacular. Instead, the model relies on deeply embossed panel lines, mechanical hull textures, and sharp engine ridges that use natural room shadows to pop on your shelf. It has been tolerance-tested on Anycubic FDM printers (such as the Kobra, Vyper, or Mega series) to guarantee clean layer transitions across its sweeping hull plates and heavy thruster pods.
Model Features
  • Anycubic Slicer Calibrated: Geometrically optimized to handle the retraction transitions between the main hull and the twin overhead engine pods without causing excessive stringing or blobs.
  • Sturdy Display Stance: The model features flat landing surfaces on its hull/landing pads, ensuring it sits securely on your desk or gaming setup without rolling.
Recommended Print Settings
  • Layer Height: 0.12mm to 0.16mm is highly recommended to cleanly capture the fine ribbing on the engines, the panel gaps, and the iconic cockpit canopy lines.
  • Infill: 10% - 15% (Gyroid or Grid provides great internal strength while keeping the overhanging engines lightweight).
  • Supports: Yes, supports are required under the main belly of the ship, the engine pods, and the front nose cone. Tree/Organic supports configured in your preferred slicer (Anycubic Next, Cura, or PrusaSlicer) work absolute wonders for clean, painless removal.
  • Brim: A 5mm outer brim is recommended to keep the support structures and the base of the ship firmly stuck to your Anycubic print bed.
StarWars
RazorCrest
Mandalorian
Mando
Spaceship
Starfighter
Gunship
Miniature
Replica
Vehicle
SciFi
Geek
DeskToy
Model
PopCulture
