2026-10-06 21:14:41
227
Mario Question Block Wall Key Holder
@Arly1122_3986543
Bring the iconic Mario question block to your wall and never lose your keys again. The long brick-textured base recreates the classic Mario platform, with a bright yellow question block embedded in the center and a raised white "?" detail. Screw holes in the four corners let you mount it firmly, and an integrated hook at the bottom holds your keyring, fob, or tracker. The question block attaches magnetically to the base — fully loaded with
6 × 10mm×3mm round magnets.
The yellow block has a built-in print pause: when the nozzle reaches the magnet pockets, the print automatically pauses, so you can lay the magnets flat into the slots and resume. The next layers seal the magnets completely inside — no exposed edges, no slipping out. The model is split into separate color parts — brown bricks, yellow block, and white symbol — that print independently and snap together. The fit is already snug, but for a durable wall-mounted daily use, a thin dab of glue at the seams makes it rock solid. Print in PLA or PETG for a retro-gaming wall organizer that doubles as nostalgic decor.
key-holder
key-organizer
wall-mount
entryway
Mario
question-block
gaming-decor
magnet
magnetic
Key
