2026-02-07 17:16:29
4.1k
225
Marshall & Peavey amp Pickbox
@Crustyforge_1101998
🎸 Guitar Amp Pick Holder – Modular & Magnetic
This guitar pick holder inspired by iconic amplifier designs is a stylish and practical accessory for every guitarist. Designed to closely match the look of real amps, it fits perfectly on your desk, in your studio, or next to your practice setup.
The model is fully modular:
  • Box and lid are interchangeable across all versions
  • Lids can be printed with or without pick slots
  • A magnetic lid keeps everything securely closed while allowing quick access
Available designs:
  • Peavey Bandit 112
  • Peavey
  • Marshall
All versions are optimized to keep the original amp look while remaining easy to 3D print.
🧲 Features
  • Magnetic lid (standard 10x2mm round magnets)
  • Modular & interchangeable parts
  • Optional pick-slot lid
  • Realistic guitar amp appearance
  • Perfect for storing guitar picks
  • Great gift for guitar players 🎶
🖨️ Printing Notes
  • supports needed
  • PLA recommended
  • Glue magnets in after printing
⚠️ Important Assembly & Printing Notes
  • Hinged lids:
  • Lids with hinges must be glued into the designated hinge connectors on the back of the box.
  • Before gluing:
  • The hinges need to be slowly and firmly bent/moved a few times to loosen them up.
  • This step is very important and must be done before gluing, otherwise the hinge may be too stiff after assembly.
  • Magnets:
  • The magnets are designed to press-fit without glue.
  • However, if you want to be extra safe—especially for frequent use—you can optionally secure them with a small amount of glue.
  • Print profile (very important):
  • The provided print profile must be used.
  • Using different settings may cause printing problems with individual parts, especially detailed elements like the front grille.
amplifier
marshall
peavey
pick
guitar
e-guitar
music
studio
desk
desk-accessory
accessory
box
amp
guitar-picks
plectrum
bandit
magnetic
modualar
storage
