2024-10-16 03:19:43
7.3k
830
Meshy Basket
@User_536_419079
Meshy Basket
Basic modern basket for everything !!
Printing recommendations & assembly
For this model you have to know where you'll use it for example if you are going to put it outside I suggest PETG otherwise inside you should use PLA.
Print the model is very easy: import everything in your slicer and rotate the nut upwards, I know it is counterintuitive but no support are needed for the basket but are necessary for the handle.
The bin is made of 3 part:
  • The basket
  • The handle (if you want to hang it)
  • The nut (if you want to hang it)
Only if you want to hang the basket somewhere you have to do some assembly:
  • Print the handle and the nut
  • Insert the handle in two holes(in the middle) of the basket
  • Push the nut over the handle pin(you may have to file it a little bit if your machine isn't very accurate)
Enjoy your Basket
Scaling & Dimensions
You need it bigger or smaller - just scale every piece at the same percentage - here are the default dimensions:
  • Internal: 274x134x95mm (10.7x5.3x3.7in)
  • External: 280x140x102mm (11x5.5x4in)
📸Image shown are of a print scaled at 95%, using eSUN white ePLA LITE
For any question or suggestions feel free to leave a comment or send me an e-mail at:📧 [email protected]
basket
chest
organizer
hook
organizer with hook
desk organizer
desk
clean
big
big organizer
big organizer hook
