2026-06-16 15:29:58
581
17
Michelangelo's David Bust - Modified 3D Scan (Print-Ready)
@saranapoli_2748076
This is a beautiful, highly detailed bust sculpture of Michelangelo's famous **David**, optimized specifically for FDM and resin 3D printing.
The model originates from a high-quality **3D scan** of the original artwork, which has been digitally cleaned, modified, and repaired to ensure flawless printing details on every slice.
### 🛠️ Key Features:
* **Flat Support Base:** The bottom of the bust has been modified with a perfectly flat, solid base of support. This ensures maximum bed adhesion and eliminates the need for complex cutting or stabilization before printing
* **Fully Scalable:** The mesh is highly detailed and optimized, meaning you can freely scale it down for a small desk ornament or scale it up to full size to make an impressive artistic display piece without losing sharpness.
* **Clean Geometry:** Digitally repaired to remove non-manifold edges, making it 100% ready for any modern slicers.
### ⚙️ Recommended Settings:
* **Orientation:** Print upright on its flat base.
* **Supports:** Tree supports are recommended for the chin, nose, and deeper curls of the hair.
* **Infill:** 10% (Gyroid works perfectly). You can increase infill or add extra walls if you want a heavier, more stone-like feel.
Download the model, scale it to your preferred size, and add a touch of classic Renaissance art to your collection! 🚀
michelangelo
david
david michelangelo
italy
art
sculpture
david sculpture
michelangelo art
david art
