2026-08-25 23:21:51
704
25
Mini Train - Functional China Diorama
@BamBamDesign_2075164
And here’s another new mini train diorama!
This time, I chose China as the theme!
The train passes by the Great Wall of China and Tiananmen Square (天安門廣場 / 天安门广场) with the Great Hall of the People(人民大會堂 / 人民大会堂), and ends at Beijing Main Station. For the train, I took inspiration from the Qinghai–Tibet Railway.
I hope that’s the correct name.
I based everything solely on reference images — of course, the scales aren’t 100% accurate, but that’s intentional.
As with the previous dioramas, you can turn the hand-wheel on the outside to let the little train drive forward.
Watch in Action on YouTube
The new Qinghai–Tibet Railway is compatible to the previous designs.
All printed parts are designed to get an good result with a 0,4 nozzle and with minimal color changes to reduce waste.
Have a look at the great Motorization solution!
More is coming…check more Mini Trains in my Collection and leave a follow👍
Printing:
Following PLA Basic Filaments are used
Silver
Brown
Black
Beige
Mistletoe Green
Green
Yellow (Train)
Other colors are possible of course, look what you have in stock.
I think it could be easy done with single color, if you want to color from hand.
I printed with a 0,4mm nozzle! Iam very pleased with the result, but you can try a 0,2 nozzle as well.
Assembly:
6pcs round 4x2 magnets are needed for the functional assembly.
You can also have a look at a assembly video from a similar model from the series: https://youtube.com/shorts/aC1mAvE9HNI
Insert 3pcs Magnets in the train and wagons with same polarityInsert 3pcs Magnets in the 3 pins all with same polarity but opposite direction than before! The Pins must attract the train!Insert the 3 pins now and use the train to hold them in place.Arrange pins and magnet approximately like thisPress the wheel in position. Check if all 3 pins are cached from the hand-wheel.
  • Terrain on top of the base and press trees in the holes. You can add a bit of glue to combine.
  • Place the train to the magnetic position and have fun 😀👍
I hope you like this little project.
If you want to support me, you can simply follow, boost & like the model.
You want to sell printed parts from my designs? Commercial license and more you get at my Patreon:
https://www.patreon.com/BamBamDesign/
MiniTrain
china
great wall
Mini
railroad
railway
Tiananmen Square
Qinghai
Tibet Railway
Tiananmen
diorama
miniature
