2026-10-09 21:30:10
196
Minimal LED lamp kit with jewelry box design 001
@makerlampit_2514690
Integrated Lighting: Tailor-made for the official Bambu 001 LED Kit (with a dedicated cable channel).
Incredible Light Diffusion: The geometric pattern on the lid plays with the thickness to create a beautiful pattern from light to dark when turned on.
Functional Design: The stepped outer edges offer a modern and clean aesthetic while ensuring a perfect fit between the lid and the base.
Easy Assembly: No glue required for the main structure—everything fits or slides perfectly into place.
🛠️ Print & Settings Tips:
Filling: 18% Giraide, you can change the filling size and the direction or texture to customize it to your liking;
Active fuzzy skin for the box;
🔌 Assembly Instructions
Insert the Bambu LED Kit 001 into the appropriate slot at the bottom of the box (use two adhesive points to hold it still).
Pass the power cord through the pre-designed rear outlet hole.
Place the inner tray/diffuser over the LED.
Close the lid, plug it in and enjoy the glow!
❤️ Do you like my work? If you print this model, share a photo of your creation and leave a 5-star review! It helps a lot to support new free designs.
jewelry
design
led
lamp
minimal
3d
3d print
easy print
kit001
creality
decor
house
wall
art
house decor
girl
ring
rings
