2026-10-04 09:22:15
260
Minimalist Accent Lamp | Free Commercial Use
@KRENNDESIGN_2043693
A minimalist, modern desk lamp designed for everyday home decor. Features a twist-lock shade mechanism, toolless assembly, and an optional insert for custom lighting aesthetics.
Bulb Compatibility: Designed for a standard E27 socket and LED bulb.
Shade & Optional Insert: Printed in Vase Mode.
Open Design & Commercial Use: All STEP files are included! Feel free to modify, remix, and sell physical prints of this lamp (Attribution required).
Hardware Required
  • 1x E27 Lamp Socket (with power cord & switch)
  • 1x E27 LED Bulb
  • 4x 9mm Silicone Rubber Pads (for the base)
Assembly Instructions
  1. Install and screw the E27 lamp socket into the base.
  2. Screw in the E27 LED bulb.
  3. Twist and lock the shade and bottom cap onto base.
  4. (Optional) Slide the insert inside the shade if you are using it.
  5. Place the top cap onto the shade to finish the assembly.
  6. Apply the 4x 9mm silicone pads to the bottom of the base — and you're ready to go!
lamp
desk lamp
table lamp
led lamp
e27
e27 lamp
ambient light
minimalist
accent light
fluted
ribbed
home
home decor
modern
night light
commercial
commercial use
