2026-10-25 02:55:21
71
Minimalist Wave Soap Dish | Self-Draining Bathroom Holder
@TheGulzar3D_2711681
💎 To get the full library of 3D models with commercial use and Custom Orders, join our Patreon here: https://www.patreon.com/thegulzar3d
🧼 Minimalist Wave Soap Dish | Keep Your Soap Dry & Lasting Longer
Clean Scandinavian lines. Maximum airflow drainage. 100% Support-Free.
Upgrade your bathroom vanity, shower ledge, or kitchen sink with the Minimalist Wave Soap Dish. Engineered with functional elegance, this holder uses a series of precision-angled ridges to elevate your bar soap above standing water, ensuring 360-degree airflow so your soap dries quickly without turning into a soggy mess.
Designed exclusively as a fast, reliable print for the Makeronline community, this monolithic one-piece model requires zero supports, uses minimal filament, and features smooth, continuous grooves that make cleaning under the faucet effortless.
✨ Key Design Features
  • 🚫 100% Support-Free: Clean, self-supporting geometry prints flat on your build plate with zero filament waste and zero cleanup.
  • 💨 Fast-Drying Ridges: Elevated V-channels minimize contact area with the soap, allowing moisture to drain and air to circulate freely.
  • 🧼 Universal Bar Fit: Generous surface area comfortably holds standard, oversized, and artisanal handmade bar soaps or kitchen sponges.
  • 🚿 Low-Maintenance & Hygienic: Smooth, sweeping valleys prevent soap-scum buildup and rinse clean in seconds.
  • ⚡ Rapid & Reliable Print: Simple, robust design with no moving parts or assembly—an ideal quick project or practical gift.
📐 Dimensions & Specifications
  • Footprint: Sized universally for standard bath and kitchen soap bars (~115 mm × 80 mm × 18 mm).
  • Print Style: Solid monolithic print (1 piece, no assembly, no glue needed).
  • Bed Compatibility: Fits easily on any FDM 3D printer (including compact 180 × 180 mm beds).
⚙️ Printing Settings
  • Support: None Required.
  • Design Note: Sloped wave ridges are completely self-supporting.
  • Orientation: Print flat on its bottom face.
  • Layer Height: 0.20 mm (or 0.16 mm for ultra-smooth ridge crests).
  • Wall Loops: 3 to 4 loops (Crucial to ensure solid, non-porous outer surfaces that resist water ingress).
  • Infill: 15% (Gyroid).
  • Material: PETG (Highly recommended for bathrooms due to superior water, chemical, and soap-scum resistance) or PLA / Matte PLA.
soap dish
soap holder
bathroom
self draining
wave tray
soap saver
home decor
minimalist
sink organizer
kitchen
tray
bandeja
support free
no support
easy print
anycubic
makeronline
creality cfs
kobra 3
stl
