2026-08-20 21:49:13
344
Mitsubishi Pajero Gear Selector Insert / Shifter Gate Cover
@passosfe_1342748
This 3D printed gear selector insert is a replacement for the plastic insert inside the automatic shifter housing of the Mitsubishi Pajero / Montero.
The original shifter insert can become scratched, damaged, cracked, or worn over time. This model is designed as a simple 3D printable replacement that fits inside the gear selector trim and follows the movement of the automatic gear lever through the PRND and manual +/- positions.
I printed mine in PETG, and the part shown in the photos has been installed in my Pajero for over one year with no issues, including regular use in a hot climate. PETG is therefore my recommended material due to its good temperature resistance and durability inside a vehicle.
  • Replacement gear selector insert
  • Fits inside the automatic shifter housing
  • Covers the opening around the moving gear lever
  • Designed for Mitsubishi Pajero / Montero
  • Compatible with the PRND and +/- shift gate layout
  • PETG recommended for automotive temperatures
  • No supports required depending on print orientation
  • Tested in real-world use for over one year
A useful replacement for anyone restoring or repairing a Mitsubishi Pajero center console, automatic shifter, gear selector, shift gate, or shifter trim without having to replace the complete shifter assembly.
pajero
montero
shifter
shift gate
gear selector
shifter insert
car interior
mitsubishi
