2026-01-31 18:23:06
622
10
Modern Minimalist Large Plant Pot Cover – 170 mm (Solid 3 mm Walls)
@Konrad_3111154
This large modern plant pot cover is designed with simplicity, durability, and clean aesthetics in mind.
With 3 mm thick walls, the model is intentionally made solid and sturdy, providing excellent strength and a premium feel after printing.
The vertical ribbed texture combined with a thick top rim gives it a timeless, minimalist look that fits perfectly in modern home and office interiors.
The model does not include drainage holes, making it ideal as a decorative pot cover for standard nursery pots.
Thanks to its straightforward geometry, this model prints cleanly without supports and delivers maximum durability when printed with 100% infill.
📐 Dimensions
  • Top diameter: 170 mm
  • Bottom diameter: 135 mm
  • Height: 161 mm
  • Wall thickness: 3 mm
🖨️ Recommended Print Settings
  • Material: PETG (recommended) / ABS
  • Layer height: 0.2 mm
  • Infill: 100%
  • Supports: No
  • Brim/Raft: Optional (recommended for ABS)
  • Print orientation: Vertical
📏 Additional Information
  • Type: Plant pot cover (no drainage holes)
  • Use case: Home decor / office decor
  • Style: Modern / Minimalist
  • Skill level: Beginner-friendly
  • Build type: Solid / Heavy-duty
plant pot
large pot cover
solid planter
thick walls
home decor
minimalist
modern design
plant
3d
print
fdm
petg
abs
cover
solid
large
livingroom
home
