2026-04-03 03:56:40
698
30
Modular Honeycomb Key Organizer
@Gennis_2720527
Organize your keys with style and creativity! 🗝️🐝
Tired of never finding your keys before leaving the house? HexaKey is the perfect solution: a modern, honeycomb-style wall key holder that is completely customizable.
The real strength of this project is its modularity. Thanks to a precision-engineered "snap-fit" system, you can combine the various hexagonal modules however you like. Start with a small layout and add new pieces as your (or your family's) key collection grows!
✨ Key Features:
  • Modular & Expandable Design: Create the shape that best fits your space. Build it horizontally, vertically, or in fun abstract shapes.
  • Easy Snap-Fit Assembly: The pegs slide into the hexagons with a gentle push. No glue or extra hardware is needed to join the pieces.
  • Modern Aesthetic: The geometric hexagonal pattern is a design classic that looks great in any entryway, garage, or office.
  • Easy & Fast to Print: All models are designed to be printed flat on the build plate, with zero material waste.
⚙️ Recommended Print Settings:
  • Material: PLA, PETG, or ABS (PETG is highly recommended for the connector pegs due to its slight flexibility).
  • Layer Height: 0.2 mm (a great balance between print speed and snap-fit accuracy).
  • Infill: 15% - 20% (Gyroid or Grid pattern).
  • Supports: ❌ NOT required. The files are optimized to print without them.
  • Build Plate Adhesion: Standard. If you tend to experience warping on sharp corners, use a Brim.
🛠️ Assembly Instructions:
  1. Print your desired number of hexagonal bases (feel free to play with different colors!).
  2. Print the connector pegs (using a contrasting color, like white on black, is highly recommended to make them pop).
  3. Arrange and snap your design together on a flat surface like a desk or table.
  4. Mount your final composition to the wall using strong double-sided tape (e.g., 3M VHB) on the back of the main hexagons.
#KeyHolder
#Organizer
#Modular
#Honeycomb
#Hexagon
No Supports
Office
