2026-10-20 06:07:39
190
8
Modular LEGO Minifigure Display Stand | Snap-Fit
@MateuszTokarz_4351639
BOM: Printed with ROSA3D Starter PLA Retro Gray
Have a growing collection of standard or custom minifigures? Stop keeping them in a drawer and display them properly! This highly customizable, modular display stand lets you build the perfect tiered shelf for your desk, display cabinet, or bookshelf.
The genius of this design is in its split parts. By printing the side panels and the shelves separately, everything prints completely flat on your build plate. This completely eliminates ugly overhangs and the need for support material! You can choose side panels for 1, 2, 3, or 4 tiers, and mix them with shelves that hold anywhere from 1 to 5 minifigures. This gives you dozens of possible combinations to build a stand that holds exactly what you need—up to 20 figures per unit!
Key Features:
  • Fully Modular: Choose between 1-4 tier side panels and 1-5 figure shelves to match the exact size of your collection.
  • Snug Press-Fit: The shelf tabs slide precisely into the side panel slots for a rigid, stable assembly-absolutely no glue required.
  • Perfectly Sized Studs: The integrated footprint studs are carefully toleranced to securely grip the feet of your standard brick minifigures.
  • Clean Print: Breaking the model down into flat-printed components guarantees a pristine surface finish without messy support scarring.
Printing Instructions:
  • Orientation: Print the side panels laying flat on their outer face. Print the shelves resting flat on their bottom surface.
  • Supports: NONE. The modular breakdown completely eliminates all overhangs.
toy
display
shelf
organizer
desk
stand
starwars
modular
trooper
figure
clone
collector
blocks
rack
showcase
collection
minifigure
tiered
lego
