2026-07-03 17:49:26
1.3k
24
Modular Magnetic Combination Soldering Workbench 模块化磁吸组合 焊锡工作台
@YGG2Any_3251657
Suitable for general household soldering needs, including storage for items like smoke extraction, lighting, solder wire spools, flux, or steel wool, as well as combination clamps for PCBs, cables, and LED strips.
适用一般性家用焊锡需求,包含排烟、灯光、焊锡丝卷轴、助焊剂或者钢丝球等物品收纳、PCB板和线缆以及灯带的组合夹具。
Main Features:
1. You can choose what to print based on your own needs—print what you need.
主要特点
1、可根据自身需求选择打印,需要什么打印什么;
2. Based on the exhaust fan, it connects quickly with magnets and supports two-way magnetic attachment. For example, a solder wire roll can be adjusted to the right side, which is convenient for left-handed welding.
2、以排烟风扇为基础,通过磁吸快速连接,且可双向磁吸,比如焊锡丝卷可调整到右侧,对习惯左手持电焊友好;
3. The light tilts downward, focusing on the welding area without dazzling the eyes.
3、灯光向下倾斜,聚焦焊接区域,不晃眼;
4. The modular clamp can hold PCBs, LED strips, and cables. PCBs can be positioned horizontally, vertically, or at 45 degrees. It supports 2.4mm thick boards. A single set of clamps can hold PCBs up to 73mm wide, and two sets can be combined to expand the capacity.
4、组合夹具,可夹PCB、灯带、线缆,PCB可横、竖、45度,兼容2.4mm厚板,单套夹具PCB夹最大可夹73mm宽PCB,可两套夹具组合扩展;
5. The push-pull snap filter is easy to remove and supports a 10mm thick filter (size 120*118*10mm).
5、推拉卡扣式滤网快拆,支持厚度10mm的滤芯(尺寸120*118*10mm)。
Both PLA and PETG can be printed. In the picture, gray-white and green are PLA, while light gray and transparent are PETG.
PLA和PETG均可打印,图中灰白和绿色是PLA,浅灰和透明是PETG。
Non-Printable Parts List:
1. DC5521 female connector, 11mm diameter (power supply sold separately). I uploaded the case STEP file, so you can modify the power socket if needed.
2. 12025 fan, I reserved screw holes for it.
3. LED strip about 10mm. Because of differences in the number of LED beads and cut points, the total length does not exceed 11.5mm.
Make sure the power supply, fan, and LED all have the same voltage.
4. Magnets, diameter 6mm × thickness 2mm, quantity as needed.
5. Filter, as needed.
非打印件材料清单
1、11mm口径DC5521母座(电源另配),我上传了壳的STEP文件,有需要改电源座的可自行修改。
2、12025风扇,我预留了螺丝孔。
3、LED灯带约10mm,因灯珠数量和剪断点不同,总长度不超过11.5mm。
电源、风扇、LED请注意统一电压。
4、磁铁直径6x厚2mm 数量按需
5、滤芯 按需
PDF
焊锡工作台+组装说明.pdf
1.09MB
PDF
Assembly Instructions (EN) .pdf
1.04MB
