2026-06-15 10:49:46
2.3k
109
Modular tool tray for D3P Kobra X overhead mount
@Darren3dprint_3680478
This is a modular tool tray for use with the D3P Kobra X overhead mount.
More details about the overhead mount can be found here:
D3P Kobra X overhead mount: Click for link
D3P Kobra X bottom riser: Click for link
The model features a tool tray that can mount on either side of the D3P Kobra X overhead mount. The tool tray mounts in the diamond shaped holes used for the side spool holders and is help in place by means of a clip. The tooltray can be mounted on either side of the D3P Kobra X overhead mount.
The tool tray features a main tray with inner compartments allowing up to 3 compartments or one large and one smaller compartments.
You can attach various components to the tool tray using the dovetails attachments on the main tray.
The following components are included:
* A deeper container that can be used to hold hair spray cannister for build plate adhesion;
* A hex tool holder;
* A cutter holder;
* A side tray for storing various items;
* A scraper holder.
You can use the same containers multiple times as all are modular.
This is a great way to have the tool tray and storage you want.
3D PRINTING
PRINT SETTINGS
IMPORTANT I upload a print setting files for all my models. The print settings has the parts positioned for correct printing with support painted.
I strongly recommended you use my print setting file. If not, I will not be able to assist you if there is an issue when printing. From experience, many of the issues with printing my models are on account of users not using my print settings.
3D PRINT SETTINGS
I use the following settings and materials to print this model:
Infill % : 15% (no need for more)
Nozzle diameter: 0.4 mm
Layer height: 0.2 mm standard
Walls: The model is set for 2 walls. Some users have reported better rigidity with 3 walls.
Material: The Anycubic Kobra S1 Max has an internal heater. PETG is the preferred choice for filament as it is about the same price as PLA but will sustain higher temps without deforming. You can also print the riser using ASA or ABS but this is more challenging due to possibility of warping. If you will only be printing PLA or PETG and will not place a dryer on the riser then you can print in PLA. This suggestion applies to the entire riser and not only the base parts.
ABOUT ME
I enjoy creating 3d models that others can use and appreciate. It is a very fun pastime. I find it very rewarding to see my models downloaded and printed. I put lots of thought, time and effort to create each model print out multiple iterations to make sure it works just right.
If you liked my model and wish to encourage me please give it a like. If you wish you can also help me with my filament costs. You can also use the discount codes listed below. You will save and I get a small commission for certain purchases. Thank you.
DISCOUNT AND AFFILIATE CODES FOR PRINTER AND FILAMENT
I am continuously trying to get discount codes from various manufacturers. Unlike many affiliate links these give discounts on purchases and are more difficult to obtain. In my requests I ask that they give me the codes with the most discounts for users even if it means a smaller commission.
HOW TO USE THE CODES
1.      You need to CLICK ON THE AFFILIATE LINK. The links are usually set up by countries/regions.
2.      Add the items you want to purchase
3.      Enter the DISCOUNT CODE at checkout. The codes vary by month and saving – so check back each month for the latest offers.
4.      You can only use ONE CODE so be certain to enter the one with the most discount
ANYCUBIC – June 26th to August 31 2026
United States - US site
AFFILIATE LINK (CLICK THIS 1ST): https://store.anycubic.com/?ref=gnsbwzea
$30 off $400+ sitewide with code ACSUN30
$25 off $300+  on selected items with code ACSUN25
$20 off $200+ on selected items with code ACSUN20
$15 off $150+ sitewide with code ACSUN15
$5 off $50+ sitewide with code ACSUN10
$3 off $30+ sitewide with code ACSUN3
$10 off – Darren3dPrint10
$15 off – Darren3dPrint15
Australia - AU site
AFFILIATE LINK (CLICK THIS 1ST): https://www.anycubic.au/?ref=Darren3dPrint
$40 off $550+ sitewide with code ACSUN30
$35 off $400+  on selected items with code ACSUN25
$30 off $300+ on selected items with code ACSUN20
$20 off $200+ sitewide with code ACSUN15
$15 off $150+ sitewide with code ACSUN10
$7 off $70+ sitewide with code ACSUN5
$4 off $40+ sitewide with code ACSUN3
CANADA - CA site
AFFILIATE LINK (CLICK THIS 1ST): https://ca.anycubic.com/?ref=Darren3dPrint
$42 off $570+ sitewide with code ACSUN30
$35 off $430+  on selected items with code ACSUN25
$28 off $280+ on selected items with code ACSUN20
$21 off $210+ sitewide with code ACSUN15
$14 off $140+ sitewide with code ACSUN10
$5 off $40+ sitewide with code ACSUN3
SPAIN - ES site
AFFILIATE LINK (CLICK THIS 1ST): https://www.anycubic.es/?ref=fldwnkel
30€ off 400€ + sitewide with code ACSUN30
25€ off 300€ + on selected items with code ACSUN25
20€ off 200€ + on selected items with code ACSUN20
15€ off 150€ + sitewide with code ACSUN15
10€ off 100€ + sitewide with code ACSUN10
5€ off 50€ + sitewide with code ACSUN5
3€ off 30€ + sitewide with code ACSUN3
10€ off – Darren3dPrint10
15€ off – Darren3dPrint15
UNITED KINGDOM - UK site
AFFILIATE LINK (CLICK THIS 1ST): https://uk.anycubic.com/?ref=xhneqmoe
£30 off £400 + on selected items with code ACSUN30
£25 off £300 + on selected items with code ACSUN25
£20 off £200 + on selected items with code ACSUN20
£15 off £150 + sitewide with code ACSUN15
£10 off £100 + sitewide with code ACSUN10
£5 off £50 + sitewide with code ACSUN5
£3 off £30 + sitewide with code ACSUN3
GERMANY - DE site
AFFILIATE LINK (CLICK THIS 1ST): https://de.anycubic.com/?ref=lbrowght
FRANCE - FR site
AFFILIATE LINK (CLICK THIS 1ST): https://fr.anycubic.com/?ref=akeofafb
EUROPE - EU site
AFFILIATE LINK (CLICK THIS 1ST): https://eu.anycubic.com/?ref=Darren3dPrint
ITALY – IT
AFFILIATE LINK (CLICK THIS 1ST): https://anycubic.it/?ref=waimpcbq
POLAND - PL site:
AFFILIATE LINK (CLICK THIS 1ST): https://anycubicofficial.pl/?ref=aakjogpi
ACSUN30
ACSUN25
ACSUN20
ACSUN15
ACSUN10
ACSUN5
ACSUN3
modular tool tray
d3p overhead
kobra x
