2024-09-22 00:31:41
34.2k
3.5k
Moon (lamp)
@Jet_Maker_5287062
Moon, based on NASA map. You can use it as a lamp by adding light and using the second file. You have to turn on vase mod, set bottom layers on 0 and you should use at least 2 perimeters (more are better, but look on your filament first). Light passes through some materials more easily than through others.
moon
lamp
nasa
