2026-04-23 20:07:09
915
13
Motorized Rail Lift
@Finniminni_5405524
I created this lift for my television because I don’t have much space in my apartment, but I do have very high ceilings. The TV moves along a vertical pillar using a gear running on a rack, guided by aluminium rails.
I used a 12V, 20RPM worm gear motor with 67 kg/cm torque (link below), controlled by an ESP32 running ESPHome (configuration file attached). The television is connected to a smart power socket, allowing the system to automatically detect when it turns on and lower the TV accordingly.
For the rails, I used inexpensive square aluminium extrusions with a side length of 11.5 mm from my local hardware store. These are mounted to the wall using the printed “Rail Holders.” I drilled through the extrusions and secured them with screws (see pictures). The carriage slides along the rails with 8 bearings (standard 22 mm skateboard bearings).
This project combines laser cutting and 3D printing, produced on my Bambu Lab H2D. The laser-cut parts are made from 3 mm wood. I’ve also uploaded STL files for these parts if you prefer to print them instead—just note that I haven’t tested the printed versions.
On the front of the carriage, I included multiple mounting holes so you can attach different devices—not just a TV. For my setup, I printed a VESA adapter that mounts the TV at an angle. Since this angle is specific to my use case, I didn’t include it in the files, but you can find it in the Onshape project.
I printed the main gear from carbon fiber-reinforced PA12, as it carries the full weight of the TV. Avoid brittle filaments here. I previously tried using PC, which unfortunately resulted in the loss of a brand-new TV. :(
In my build, I also added a cable chain and a steel cable system with a concrete counterweight. However, since this setup is highly specific to my installation, I didn’t include it in this upload. If you’re interested, you can explore it in the Onshape project.
This system—especially without counterweights—only works for very light TVs. Mine weighs around 8 kg, and without the counterweight, the motor can barely lift it. The counterweight also acts as a safety feature, preventing the TV from falling freely if something fails. Please make sure to implement your own safety solution if you attempt a similar build. I’ve already lost one TV to this project, and fortunately no one was hurt. Please be careful. I take no responsibility for any damage. This project is intended for experimentation only.
I realize this is a highly custom project that may not get many downloads, but I wanted to share it as a guide or source of inspiration for anyone interested in building something similar.
Onshape Project:
https://cad.onshape.com/documents/cb5b4dc9849813ce430c1e02/w/09174822e99dd4d3f5166570/e/484217fc140e615856e31628?renderMode=0&uiState=69e7f565bdff45cbfe24207a
Parts I used:
motor
gear
laser
electronics
home
tv
smart
esp32
rack
screen
rail
automatic
project
motorized
lift
homeassistant
television
elevator
esphome
