2026-09-25 15:58:58
1.5k
171
Multi-Angle Bed Phone Stand
@Tomasz_1742866
📱 Multi-Angle Bed Phone Stand
One stand – multiple positions and viewing angles.
A practical smartphone stand designed for comfortable phone use in bed, while also working perfectly on a desk, bedside table or sofa.
The main feature of this design is its multiple positioning options. By changing the way the phone is placed in the stand, you can achieve different viewing angles and use your phone in both landscape and portrait orientation.
The photos show several example positions – from the phone placed horizontally at a steeper angle, through a flatter landscape position, to different portrait orientations.
This makes it easy to adjust the phone to your preferred position and find the most comfortable viewing angle for watching videos, browsing the web, making calls or simply using your smartphone while relaxing.
🖨️ Recommended Print Settings
  • Material: PLA
  • Nozzle: 0.4 mm
  • Layer height: 0.20 mm
  • Infill: 10–15%
  • Walls: 3–4
  • Supports: Not required
The model is designed for easy FDM printing and does not require complicated print settings.
⭐ Features
  • multiple phone positions
  • portrait and landscape orientation
  • multiple viewing angles
  • ideal for bed, desk or bedside table
  • simple to use
  • easy to print
  • no supports required
Print it once and position your phone the way you like.
phone stand
phone holder
smartphone stand
bed phone stand
bedside phone holder
multi angle
multi position
adjustable phone sta
desk phone stand
phone dock
no supports
mobile stand
smartphone holder
