2026-07-04 07:01:51
1.5k
172
NASA Saturn V Moon Rocket Replica
@dharian_5531540
"We choose to go to the Moon!" — Bring the mightiest machine in human history to your display shelf!
This is a highly detailed, 3D-printable scale model of NASA’s legendary Saturn V rocket, the launch vehicle that propelled the Apollo astronauts to the Moon. Every stage—from the massive F-1 engine cluster at the base of the S-IC stage, up through the S-II and S-IVB stages, all the way to the Apollo Command Module and Launch Escape System—is beautifully represented.
This model has been specifically engineered for single-color printing. You don't need a multi-material system or automated filament changers to get a museum-quality look. The surface details, corrugation textures, and stage separators are deeply embossed, relying on natural shadows and highlights to pop sharply. It has been tolerance-tested to print seamlessly on Anycubic FDM printers (such as the Kobra, Vyper, or Mega series), minimizing vertical wobble and ensuring clean z-axis layers.
Model Features
  • Single-Color Optimized: Designed to look incredible using just one spool of filament. The physical geometry maximizes contrast so the iconic USA markings and American flag details stand out naturally.
  • Anycubic Slicer Calibrated: Geometrically optimized to prevent standard tall-print issues like z-wobble, layer shifts, or aggressive stringing on standard Anycubic extruder setups.
  • Sturdy Display Base: Features a stable, well-balanced footprint so your rocket stays securely upright on your desk or gaming setup.
Recommended Print Settings
  • Layer Height: 0.12mm to 0.16mm is highly recommended to cleanly capture the fine ribbing on the rocket body, the small fins, and the delicate escape tower at the top.
  • Infill: 10% - 15% (Gyroid or Lightning infill works best to keep the top of the rocket lightweight, reducing the risk of tipping during printing).
  • Supports: Minimal. Supports are only required under the small fins at the base and the overhangs of the engine nozzles. Tree/Organic supports in your preferred slicer (Anycubic Next, Cura, or PrusaSlicer) are highly recommended for effortless removal.
  • Brim: A 5mm to 8mm outer brim is mandatory for this print due to its height-to-width ratio, ensuring it stays firmly anchored to your Anycubic print bed.
NASA
SaturnV
Apollo11
MoonRocket
Space
Rocket
Astronomy
ScaleModel
Anycubic
SingleColor
DeskToy
Science
History
Display
Replica
Miniature
3DPrint
Geek
SpaceX
