2026-10-20 21:40:47
637
108
NIght Fury Toothless Dragon - Halloween Multipart Figure
@poneko_1917645
Toothless is ready for pumpkin season! Inspired by the beloved Night Fury from How to Train Your Dragon, this Halloween version pairs his familiar playful expression and bright green eyes with a purple wizard hat and an orange Jack-o’-lantern held between his paws.
With spread wings, a curled tail, and a seated pose, he brings a festive twist to your desk or shelf. The pumpkin is hollow, with open eyes, nose, and mouth—add a battery-powered LED tea light inside for a warm Halloween glow.
Engineering, Printing & Assembly (Multi-Part)
This model is available exclusively as a multi-part project, with colors separated for individual printing and assembly.
• Scale & sizing: Designed at a default assembled height of 200 mm, including the hat. It can be scaled, but check joint tolerances and the pumpkin’s internal clearance when resizing.
• No AMS required: Print the components separately using Dark Gray or Black, Purple, Orange, and Green filament.
• No multi-color purge waste: Separate color prints avoid repeated filament swaps and the associated purge towers.
• Surface quality: A 0.12–0.16 mm layer height is a good starting point for detailed surfaces such as the face, hat, and pumpkin.
• Supports: Some components may require targeted supports depending on their orientation and your printer settings. Review the slicer preview before printing.
Test-fit all parts before applying glue. Once everything aligns, use small amounts of CA glue on the joints. Keep the pumpkin’s lighting access clear so the LED tea light remains removable.
Display & Lighting
The dark body, purple hat, green eyes, and orange pumpkin give Toothless a classic Halloween palette while preserving his recognizable charm. Display him with the pumpkin unlit or place an LED tea light inside to illuminate the carved face.
halloween
dragon
figure
multipart
toothless
pumpkin
SpookyCute
DragonFigurine
night fury
toothless dragon
nigh fury toothless
decor
halloween decor
kids
toys
