2025-01-17 03:51:59
2.1k
247
Nintendo Switch 2 - Official Logo Keychain Pack!
@Powerpillprints_2496744
This pack has been all set up for super simple and easy printing with the AMS or AMS lite!
All the models are set to 4 Colours! Just load your filament, slice and go!
Boost MeIf you enjoyed these keychains, please consider boosting to support the creator. Thank you and make sure to check out my other packs for your favourite Pokémon!
These keychains take between 45 minutes to 1.5h to print!
This Keychain pack includes TWO versions of the Official Nintendo Switch 2 logo. There is a a square and rounded version to choose from.
I have this set to use the 0.4mm nozzle with a .28mm layer height. This prints three layers of colour so the colours turn out nice and saturated and minimize waste. After the colour, there's one solid black layer, three layers of infill, and four final solid layers for the back for strength with the back pattern set to Hilbert Curve for a nice texture. There is a small hole in each model which is just large enough to fit a 1mm keychain jump ring. If you find it too small, you can modify the size of the “Keychain hole” object in BambuStudio to make it a little larger, or take a small drill bit and drill the final keychain to make it a little bigger!
I purchased my keychain set from Amazon if you'd like to get something similar!
I made some changes to the first layer and first layer infill speeds, reducing them both by about half. This increases the print time for the first layer, but increases the bed adhesion and print quality a bit. If you find that the first layer is printing too slow for your liking, feel free to reset them both back to default settings in the speed tab.
Want to remove the keychain hole? No problem! Each keychain has a “Keychain hole” object on each plate. Just select it, delete it, and re-slice!
Want to scale these up really large to make some wall art? Just delete the “Keychain hole” object, then scale the X and Y axis to fit your print bed. Keep the Z-Scale back to 3.08mm so you're not printing extra layers though!
If you notice any settings that could be changed or improved, please let me know! I'd love to make any adjustments necessary so they all print great! If there's any other keychains you want to see, leave a comment!
nintendo
nintendo switch 2
nintendo switch
Logo
Keychain
