2026-08-20 20:45:49
518
43
No-Waste Chicken Feeder / Comedero 2en1 Gallinas y Codornices - Floor & Cage Mount
@DrCar_4680089
Keep your coop clean and stop wasting feed! 🐔🌾
This gravity feeder is specially engineered for chickens, quails, and chicks, designed to prevent birds from flicking feed onto the floor.
✨ KEY FEATURES:
  • Versatile 2-in-1 Mounting:
  • 🟢 Floor Standing: Broad, rock-solid, tip-resistant base.
  • 🟢 Cage / Wall Mounted: Features a rear hole + custom 3D printable bolt & ergonomic wing nut included to easily clamp directly onto wire mesh or cage bars—no extra hardware needed!
  • No-Spill Feed Holes (Ø 45 mm): Optimized size for easy eating while preventing feed mess and contamination.
  • Fitted Top Lid: Keeps grains dry, clean, and safe from dust or debris.
  • 100% 3D Printable: Zero hardware store trips required. Print, assemble, and feed!
📐 DIMENSIONS:
  • Total Height: 23 cm
  • Width: 20 cm
  • Depth: 10 cm
  • Feeding Area Height: 5 cm
  • Feed Hole Diameter: 45 mm
📦 INCLUDED STL / 3MF FILES:
  1. Main Feeder Body (3-port gravity hopper)
  2. Top Protective Lid
  3. 3D Printable Threaded Bolt
  4. Ergonomic Hand-Tight Nut
⚙️ RECOMMENDED PRINT SETTINGS:
  • Filament: PETG (recommended for outdoor use & easy washing) or PLA+.
  • Walls/Perimeters: 3 to 4 (for durability).
  • Infill: 15% – 20% (Gyroid recommended).
  • Supports: None (or minimal depending on orientation).
⭐ If you find this model useful, please leave a like, download, and post your print!
¡Mantén el corral limpio y a tus aves bien alimentadas sin tirar ni un grano de comida! 🐔🌾
Este comedero por gravedad está diseñado específicamente para gallinas, codornices y pollitos, optimizado para evitar que escarben o tiren el alimento.
✨ CARACTERÍSTICAS PRINCIPALES:
  • Doble Sistema de Uso (2 en 1):
  • 🟢 De suelo: Base ancha y súper estable, anti-vuelco.
  • 🟢 Para jaula / colgado: Incluye orificio trasero + tornillo y tuerca ergonómica impresos en 3D para fijarlo fácilmente a mallas o jaulas sin necesidad de ferretería extra.
  • Agujeros Anti-Desperdicio (Ø 45 mm): Perfectos para que coman cómodamente sin poder sacar la comida fuera.
  • Tapa Superior Ajustada: Protege el alimento del polvo, humedad y suciedad.
  • 100% Imprimible: No necesitas comprar tornillos de metal ni piezas adicionales. ¡Imprimir y usar!
📐 DIMENSIONES:
  • Alto total: 23 cm
  • Ancho: 20 cm
  • Fondo: 10 cm
  • Altura zona de comida: 5 cm
  • Diámetro de orificios: 45 mm
📦 EL ARCHIVO INCLUYE:
  1. Cuerpo del comedero (tolva con 3 huecos)
  2. Tapa superior protectora
  3. Tornillo de fijación 3D
  4. Tuerca ergonómica tipo palomilla / pomo
⚙️ AJUSTES DE IMPRESIÓN RECOMENDADOS:
  • Material: PETG (ideal para exterior/lavado) o PLA+.
  • Capas de pared: 3 o 4 (para máxima resistencia).
  • Relleno (Infill): 15% - 20% (Gyroid o Grid).
  • Soportes: No necesarios (o mínimos según orientación).
⭐ ¡Si te gusta el diseño, deja un like, descarga y comparte tu Make!
chicken feeder
comedero gallinas
comedero codornices
quail feeder
poultry feeder
comedero tolva
no waste feeder
anti desperdicio
3d printed feeder
accesorios granja
cage feeder
comedero jaula
floor feeder
comedero suelo
coop accessories
gallinero
bird feeder
tolva aves
farming diy
