2026-06-29 18:04:51
645
25
Nosk from Hollow Knight - Split model
@TheLightning_2558699
Nosk is a terrifying shape-shifting spider creature from Hollow Knight, faithfully recreated as a detailed 3D printed figure capturing its iconic spider body, long curved legs, and the haunting false mask dangling from its chest. Its intricate details, from the flowing mane to the glowing red accents that make Nosk one of the most unsettling bosses in Hallownest… and… it glows oO
I also realized I did not print out and attach the front arms… sigh. I already took the photos, they should fit…
INSTRUCTIONS
This is an annoying one, but if you ever assembled my models; you know you are in for some frustration and glue on your fingers :D
Print everything out, and assemble the legs. Remember if you are using superglue, very tiny amounts are needed to join the legs together.
The legs come in two variations, with a cable run to pass a wire for the inner glow, and solid. The cable ones are much much more annoying to glue. The cable must be ultra fine, since you only have 4mm of space. I used aRGB and a addresable LED controller for mine (more details an pics to follow)
once done, glue the torso together, inserting the orange belly. Try your best to keep it as aligned as possible. Later insert the legs and spines.
If they dont seem to fit, or the legs are not all aligned to the floor DO NOT PANIC!
For this one, hot water, hair dryer or a blowtorch lighter is a must. Soften the plastic a bit and insert it to get the correct shape or bend the leg so it is flat to the ground. The holes were designed to be symmetrical, but after gluing, they are not going to be.. and thats fine, Nosk is weird, so heat it and bend his legs any way you want to make it unique (its a feature!)
Any issues, shoot me a comment.
hollow knight
nosk
fan art
boss figure
spider
3d printed
video game
figurine
collectible
indie game
hallownest
horror
creature
display model
gift for gamer
