2025-10-06 20:12:01
895
Nothing Box:打不开的机关盒 An inoperable fuse box
由于 pdf 视频播放不正常,拆开视频链接我放在这里
这,是一个机关盒——Nothing Box
关于五金,你需要:
  • 12*3 磁铁 3 颗
需要 502 粘合
组装详见说明文件
预估解密时间:25---50min,有玩 puzzle 经验者可以更短一些
背景故事:太忙了,来不及写,后续会补上的
Due to the PDF video not playing properly, I opened the video link and put it here.
This is a puzzle box — Nothing Box.
For the hardware, you will need:
  • 12*3 magnets, 3 pieces
502 adhesiveAssembly
instructions can be found in the instruction file.
Estimated time to solve: 25–50 minutes; those with puzzle experience may take a bit less.
Background story: Too busy to write it now, will add later.
盒顶可以黏上“Nothing Box”的铭牌
建议:对所有结构上油,否则可能因为打印精度较低卡住
务必清理所有毛刺(推荐使用尖嘴钳)
A 'Nothing Box' nameplate can be attached to the top of the box. Highly recommended: lubricate all structures, otherwise it may get stuck due to low printing accuracy.
Be sure to remove all burrs (using needle-nose pliers is recommended).
关于打开,请熟读并背诵以下口诀:
不许暴力!不许暴力!不许暴力!
(呵呵)
Regarding puzzles, please carefully read and memorize the following mantra: No violence! No violence! No violence! (Hehe)
内部结构一赏:
盒子
机关盒
玩具
益智玩具
PDF
Nothing Box 组装指南.pdf
15.77MB
