2025-10-18 09:31:28
2.6k
56
Nothing Island Piece(Ferris wheel)——一个静谧的小公园 A quiet mini park
The English version is below
隆重介绍:Nothing Island 首个分体版本——Nothing Island Pieces
虽然外观接近 Nothing Island,但结构都是新的(如约1:14 减速齿轮组),而最重要的是,它实现了 100% 分件多色,总计 最多14色,单色打印机也可驾驭。
相比 Nothing Island,我重新设计了摩天轮舱位,主轮,传动轮,路灯,甚至为它加了个长椅
但分件多色的代价是,你需要 502 和一定的手工经验(哈哈)
由于是分体版,我就不写背景故事了,具体可以详见这里
五金清单:
1、创客新手套装(需要 030 电机*1,1:49.7 减速齿轮组*1,黄色橡皮筋*2,电池簧片*4,4*2 磁铁*10,连接线*2,BT3*8 螺丝若干)
2、3*30 直销轴*4
另需要大量 502 胶水以粘连,内六角扳手拧螺丝
已知问题:传动噪音较大,摩天轮转动不平稳,后期会改进
对于所有传动结构,强烈建议上油/上蜡润滑,并打磨好所有毛刺,清除所有支撑,否则可能无法传动
虽然部件很精细,但已经试验过均可以在 0.4mm 喷嘴上打印且效果不错,个人觉得没有使用 0.2mm 喷嘴的必要,但组装要小心损坏零件。
虽然已经测试过,但由于不同打印机有不同公差,如果传动系统有问题或者拼装困难:
你看着办,能动,装上就行
推荐使用夜光耗材作为灯罩,木质耗材做长椅,如果没有也可以换成普通耗材配置中是我认为最佳的色彩方案,共 14 色,如果找不齐可以将相近颜色合并(其实连我耗材都找不齐哈哈)
提供详细 pdf 组装说明,无需担心组装困难问题
Grand Introduction: Nothing Island's First Modular Version — Nothing Island Pieces
Although it looks similar to Nothing Island, the structure is all new (such as the approximately 1:14 reduction gear set), and most importantly, it achieves 100% modular multi-color assembly, with up to 14 colors in total, which a single-color printer can also handle.
Compared to Nothing Island, I redesigned the Ferris wheel cabins, main wheel, drive wheel, lampposts, and even added a bench.
However, the price of modular multi-color assembly is that you need 502 glue and some hands-on experience (haha).
Since this is a modular version, I won’t write a background story.
For details, you can refer here.
Hardware List:
1. Maker Beginner Kit (requires 030 motor *1, 1:49.7 reduction gear set *1, yellow rubber bands *2, battery contacts *4, 4*2 magnets *10, connecting wires *2, BT3*8 screws, and some)
2. 3*30 direct-drive shafts *4Additionally, you'll need a large amount of 502 glue for bonding and an Allen wrench to tighten screws.
Known Issues: The drive is relatively noisy, and the Ferris wheel does not rotate smoothly — improvements will be made later.
For all drive mechanisms, it is strongly recommended to oil/wax and smooth out all burrs, and remove all supports, otherwise it may not rotate properly.Although the parts are very detailed, they have been tested successfully on a 0.4mm nozzle with good results.
Personally, I don't see the need to use a 0.2mm nozzle, but be careful during assembly to avoid damaging the parts.
Although tested, different 3D printers have different tolerances.
If the drive system has issues or assembly is difficult:Do as you see fit, as long as it works when assembled.
It is recommended to use glow-in-the-dark filament for lampshades and wood filament for the bench.
If unavailable, regular filament can be used. This is the color scheme I consider optimal, with 14 colors in total. If you cannot find all colors, similar colors can be merged (in fact, I can't even find all my filaments haha).
Detailed PDF assembly instructions are provided, so there is no need to worry about assembly difficulties.
微缩
电动
机械
电机
组装
分件多色
多色
摩天轮
Nothing
Nothing Island
PDF
Nothing Island Piece(Ferris wheel)组装指南.pdf
15.09MB
