2026-09-29 03:30:38
2.3k
320
OPTICAL ILLUSION FIDGETS – Two Designs
@Tomasz_1742866
🌀 OPTICAL ILLUSION FIDGETS – TWO DESIGNS
Two different kinetic fidgets with optical illusion effects, designed to rotate and create unusual and fascinating movements.
The project includes 2 designs:
  • ⚙️ Gear Cross – a gear-based mechanism with interlocking gears, creating an interesting visual effect while rotating.
  • 🌀 Spiral Vortex – a spiral construction creating a smooth, hypnotic optical effect and satisfying movement.
📦 TWO OPTIONS FOR EACH DESIGN
For each of the two models, two plates are included:
  • Plate 1 – Ready to Print – a complete version of the model prepared for direct printing.
  • Plate 2 – Full Housing – the complete housing intended to be split into parts manually in your slicer, if you need to adapt the model to your printer's build volume.
🚨🔥 NEW VERSION AVAILABLE! 🔥🚨
🌀⚙️ OPTICAL ILLUSION FIDGETS – TWO NEW DESIGNS ⚙️🌀
⭐ A NEW COLLECTION WITH 2 COMPLETELY DIFFERENT MECHANISMS! ⭐
👇👇👇 CHECK OUT THE NEW VERSION HERE! 👇👇👇
🔗 OPTICAL ILLUSION FIDGETS – Two New Designs
⚙️ Planetary Gear Fidget + 🌀 Spiral Vortex II
Two new mechanisms. Two new movements. A completely new optical experience!
Print once – fidget forever! 🌀
Perfect as a desk toy, kinetic toy, fidget, mechanical model, or simply an interesting geometric object to watch, spin, and play with.
optical illusion
fidget
fidget toy
kinetic toy
desk toy
gear cross
spiral vortex
mechanical toy
optical illusion toy
stress relief
relaxing
satisfying
kinetic ar
mechanical
geometric
