2026-04-30 09:46:20
2.2k
88
Omni Press
@Finniminni_5405524
I wanted a drill press for my Dremel, as well as a dedicated press for installing heat-set inserts with my soldering iron. Since there are already many great standalone designs for both, I decided to combine these functions into a single, versatile tool.
This press features a quick-lock system that allows you to easily swap between different tools in seconds. Whether you're drilling or working with heat-set inserts, the transition is fast and hassle-free.
I’ve included design references so you can create your own tool holders. You can adapt the system to fit other tools and expand its functionality. If you do create your own attachments, feel free to share them with others!
All design files are available on Onshape. and a PDF with reference dimensions for custom tool holders is included to help you get started.
Detailed assembly instructions are available in the Assembly PDF.
press
tool
iron
multi
drill
soldering
workshop
screw
tools
thread
solder
sturdy
inserts
milling
dremel
drilling
threaded
heated
insert
inset
PDF
Custom Tool Reference Guide 2.pdf
107.35KB
PDF
Assembly Instructions.pdf
3.38MB
PDF
Part List.pdf
106.74KB
