2026-05-01 18:15:07
662
11
One-Hand Airbrush Palette Dispenser – IKEA Skadis / Skådis Compatible
@IlkekkoLab_4847706
A Skådis-mounted dispenser for airbrush mixing cups: slide one out from the bottom with one hand, the rest of the stack drops down ready for the next.
When you're airbrushing you've got a brush in one hand and a paint bottle in the other. Digging through a stack of metal mixing cups to separate one is exactly the friction you don't need. This holder loads from the top and dispenses from the bottom — pull a cup out sideways, the column reloads itself.
Features:
  • Bottom slide-out dispensing — grab a cup one-handed, no separating, no fumbling
  • - Auto-feed stack: the column drops as you pull
  • - Top-loading, holds a full stack of standard airbrush mixing cups
  • - Integrated Skådis clips — no screws, no extra hardware
  • - Print-in-place, no assembly
  • - Compact footprint, doesn't crowd the pegboard
Print settings:
  • Layer height: 0.20 mm
  • - Infill: 15%
  • - Supports: yes (tuned tree supports — already configured in the print profile)
  • - Material: PLA
  • - Print time: ~46 min
  • - Filament: ~20 g
Assembly notes:
Print profile ships ready-to-slice on Bambu Lab P2S with supports configured for a clean dispensing slot. Snap off the support under the front opening with flush cutters and check the slot is clear before mounting. Load cups from the top.
If this speeds up your paint station, a boost helps it reach more airbrushers. Drop a make with your setup — remixes for different cup sizes welcome.
skadis
skådis
ikea
airbrush
airbrushing
paintingtools
miniaturepainting
modelmaking
paletteholder
mixingcups
dispenser
onehand
pegboard
organizer
workshop
printinplace
bambup2s
hobby
ilkekkolab
useful
