2025-09-24 00:47:31
4.7k
478
Orca Cube Test - Kobra S1
@Flavia_1779827
The Orca Cube Test is a quick calibration model for the Anycubic Kobra S1 (and S1 Combo). This 30 mm cube helps you evaluate dimensional accuracy, extrusion flow, and print stability in a simple, repeatable way.
What it tests:
  • X/Y/Z dimensional accuracy (30 mm target)
  • Flow calibration (under- or over-extrusion)
  • Layer consistency and alignment
  • Ringing/ghosting on edges
TTips:
  • Print at default scale with your standard profile.
  • Measure each axis with calipers and compare to 30 mm.
  • Use results to fine-tune flow, steps, or belt tension.
A clean, reliable benchmark to keep your Cobra S1 properly tuned.
orca
cube
cubo
test
teste
kobra s1
combo
kobra
s1c
