2025-07-13 19:23:09
2.2k
133
Oreo Lens Cap 58mm
Print Profile Files (4)
Raw Model Files (7)
- All Printers
- Kobra 3
- Kobra S1
- Kobra 3 Max
- Kobra 3 V2
- Kobra X
- Kobra 4
No data
Add
Oreo 0.2 mm layer, 2 walls, 7% infill
bigovereasy
Upload:2025-07-13 19:39
Kobra 3
Kobra S1
Kobra 4
Kobra X
Kobra 3 V2
Kobra 3 Max
PLA
:7.37g
PLA
:15.08g
0.4 mm nozzle
Plates(4)
Plates 1 - Oreo_58wm
0.2mm layer /
42m 46s
PLA:7.37g
PLA:1.27g
Plates 2 - squiggle
0.2mm layer /
19m 13s
PLA:3.54g
Plates 3 - Clip(Optional)
0.2mm layer /
25m 54s
PLA:7.01g
Plates 4 - Ring (Optional)
0.2mm layer /
12m 57s
PLA:3.26g
Designer
Kobra 3
Kobra S1
Kobra 4
Kobra X
Kobra 3 V2
Kobra 3 Max
/ Plates:4
/ 1h 40m 50s
Canon 0.2 mm layer, 2 walls, 7% infill
bigovereasy
Upload:2025-07-13 19:45
Kobra 3
Kobra S1
Kobra 4
Kobra X
Kobra 3 V2
Kobra 3 Max
PLA
:6.15g
PLA
:16.29g
0.4 mm nozzle
Plates(4)
Plates 1 - Canon_58wm
0.2mm layer /
42m 27s
PLA:6.15g
PLA:2.48g
Plates 2 - squiggle
0.2mm layer /
19m 13s
PLA:3.54g
0.2mm layer /
25m 54s
PLA:7.01g
0.2mm layer /
12m 57s
PLA:3.26g
Designer
Kobra 3
Kobra S1
Kobra 4
Kobra X
Kobra 3 V2
Kobra 3 Max
/ Plates:4
/ 1h 40m 31s
Nikon 0.2 mm layer, 2 walls, 7% infill
bigovereasy
Upload:2025-07-13 19:46
Kobra 3
Kobra S1
Kobra 4
Kobra X
Kobra 3 V2
Kobra 3 Max
PLA
:6.15g
PLA
:16.29g
0.4 mm nozzle
Plates(4)
Plates 1 - Nikon_58wm
0.2mm layer /
42m 30s
PLA:6.15g
PLA:2.48g
Plates 2 - squiggle
0.2mm layer /
19m 13s
PLA:3.54g
0.2mm layer /
25m 54s
PLA:7.01g
0.2mm layer /
12m 57s
PLA:3.26g
Designer
Kobra 3
Kobra S1
Kobra 4
Kobra X
Kobra 3 V2
Kobra 3 Max
/ Plates:4
/ 1h 40m 34s
More profile
Select the Files to open
Tips
Download Print Profile Files
Tips
Coins reward
89
104
- New Collection
New Collection
Share
Facebook
Pinterest
Twitter
Reddit
- Copy link
Coins reward
Model Information
Comments & Ratings
Remixes
Related Models
Lens cap with a mounting diameter of 58mm
The spring slot is tapered, so insert the spring first from one side, then stretch it from the other side so the spring edge fits into the slot, then press the center all the way down.
I also made a clip that attaches to a strap and holds the lens cap.
The ring acts as a lens emulator, but I’ll leave it as an optional par
you can attach two caps on opposite sides, making it a full Oreo cookie.
As a bonus, I added three versions with "Canon," "Sony," and "Nokon" inscriptions.
Personal use only ⚠ No commercial
👉 Check My Patreon 👈
oreo
cap
lens
lenscap
cookie
The model cannot be found
