2026-08-12 03:02:50
5.6k
787
PIP Ball Bearings | 36 Sizes | 608 6000 6200 6300
@Zdesign_5795545
36 print in place ball bearings. One geometry. Verified clearance.
A complete family of ISO standard deep groove ball bearings that print fully assembled and spin straight off the bed. From a 5 mm bore up to 30 mm.
Verified, not estimated
Every size was measured solid to solid in CAD before release.
  • Ball to race clearance: 0.150 mm on all 36 sizes
  • Minimum ball to ball gap: 0.101 mm
  • Interference on any model: none
This matters because clearance is a property of your printer, not of the bearing. Keeping it identical across the whole family means that once you have dialled in one size, every other size behaves the same way.
What is included
Series 6000 · light and narrow
  • 608 · 8 × 22 × 7 mm · 9 balls
  • 6000 · 10 × 26 × 8 mm · 9 balls
  • 6001 · 12 × 28 × 8 mm · 10 balls
  • 6002 · 15 × 32 × 9 mm · 11 balls
  • 6003 · 17 × 35 × 10 mm · 11 balls
  • 6004 · 20 × 42 × 12 mm · 10 balls
  • 6005 · 25 × 47 × 12 mm · 12 balls
  • 6006 · 30 × 55 × 13 mm · 12 balls
Series 6200 · light, the most common in industry
  • 6200 · 10 × 30 × 9 mm · 7 balls
  • 6201 · 12 × 32 × 10 mm · 8 balls
  • 6202 · 15 × 35 × 11 mm · 9 balls
  • 6203 · 17 × 40 × 12 mm · 9 balls
  • 6204 · 20 × 47 × 14 mm · 8 balls
  • 6205 · 25 × 52 × 15 mm · 10 balls
  • 6206 · 30 × 62 × 16 mm · 10 balls
Series 6300 · medium, higher load
  • 6300 · 10 × 35 × 11 mm · 6 balls
  • 6301 · 12 × 37 × 12 mm · 7 balls
  • 6302 · 15 × 42 × 13 mm · 7 balls
  • 6303 · 17 × 47 × 14 mm · 7 balls
  • 6304 · 20 × 52 × 15 mm · 7 balls
Series 6800 · thin section
  • 6800 · 10 × 19 × 5 mm · 17 balls
  • 6801 · 12 × 21 × 5 mm · 19 balls
  • 6802 · 15 × 24 × 5 mm · 23 balls
  • 6803 · 17 × 26 × 5 mm · 25 balls
  • 6804 · 20 × 32 × 7 mm · 19 balls
  • 6805 · 25 × 37 × 7 mm · 23 balls
  • 6806 · 30 × 42 × 7 mm · 27 balls
Series 6900 · thin section, medium
  • 6900 · 10 × 22 × 6 mm · 12 balls
  • 6901 · 12 × 24 × 6 mm · 13 balls
  • 6902 · 15 × 28 × 7 mm · 14 balls
  • 6903 · 17 × 30 × 7 mm · 15 balls
  • 6904 · 20 × 37 × 9 mm · 13 balls
  • 6905 · 25 × 42 × 9 mm · 15 balls
Miniature
  • 625 · 5 × 16 × 5 mm · 8 balls
  • 626 · 6 × 19 × 6 mm · 8 balls
  • 698 · 8 × 19 × 6 mm · 11 balls
Print settings
  • Layer height · 0.20 mm, drop to 0.12 mm for the 6800 series
  • Nozzle · 0.4 mm
  • Walls · 3
  • Infill · 25 percent
  • Ironing · off, it will weld the balls to the outer race
  • Orientation · flat on the bed, as supplied
Three things that decide whether it spins
1. Calibrate your flow. The gap is 0.15 mm. Over extrusion of 5 percent closes it and the bearing comes out as a solid disc.
2. Set elephant foot compensation. First layer squish is what fuses the balls to the race at the bottom. This is the single most common failure.
3. Break it in. Straight off the bed it will feel locked. Grip the outer ring, twist the inner ring firmly, you will feel it click free, then spin it a few times. That is normal and by design.
Material
PLA gives the crispest detail and the best separation. PETG runs smoother once freed but strings into the races, so slow the travel moves down. ABS and ASA work, though shrinkage eats into the clearance.
An honest note on the thin series
Sizes 6800 through 6803 carry balls of only 2.52 mm, up to 25 per row. They are geometrically correct and they slice, but on a 0.4 mm nozzle they sit right at the edge of what FDM can separate.
Print one before you commit to a set, and drop to a 0.12 mm layer height. Everything from 6804 upwards is comfortable.
The sizes are real
These are ISO 15:2017 standard dimensions, so anything designed around a real 6002 will accept the printed one.
Useful for prototypes, jigs, camera rigs, lazy susans, spinners, filament spool holders and dusty places where you would rather not sacrifice a steel bearing.
bearing
ball bearing
608
6000
6200
spinner
bearings
print in place
