2026-10-21 14:27:52
3.3k
290
Panther Tankhead Mech, easy to print and assemble, movable gun barrel, gear joints, World War II
@Meowcraft_2417143
This model is inspired by concept art by Emerson Tung.
It is based on the WWII German Panther tank.
The following are assembly notes:
1. Pliers and glue are required for assembly.
2. All joints use bolts that cannot be removed after assembly. Therefore, please read the instructions carefully before assembly and perform a preliminary assembly.
3. Most joints are one-piece printed gear joints. They need to be separated after printing.
4. PLA can be used as the frame, but I recommend using PETG.
5. Due to material limitations, ball joints and gear joints may loosen over time. Loose ball joints can be treated with model damping glue. I haven't found a solution for loose gear joints yet. Please let me know if you have any suggestions.
6. Please leave a comment if you have any questions.
The finished product is approximately 25cm tall.
tank
mech
World War II
PDF
豹式 坦克头机甲 说明书.pdf
4.15MB
