2024-09-03 08:53:02
2.3k
247
Parametric Viking Pendant
@Mhatey3D_5146866
Viking Pendant with Parametric Knotwork
Description:
This customizable Viking pendant features a unique, parametric knotwork design that can be easily adjusted to suit your preferences. The design is based on a circular pendant with a central hole, and the knotwork pattern is created using a series of interconnected cylinders.
Key Features:
  • Parametric Design: Easily adjust the pendant's size, thickness, knot thickness, and number of knots to create a truly personalized piece.
  • Knotwork Pattern: The intricate knotwork design adds a touch of Viking heritage and style.
  • Customizable Hole Size: Choose the desired hole size for attaching a cord or chain.
  • 3D Printable: The model is designed for 3D printing, allowing you to create a physical pendant.
Customization Options:
  • Pendant Diameter: Adjust the overall size of the pendant.
  • Pendant Thickness: Control the thickness of the pendant.
  • Hole Diameter: Set the size of the central hole.
  • Knot Thickness: Modify the thickness of the individual knot elements.
  • Number of Knots: Determine the complexity of the knotwork pattern.
Usage:
OpenSCAD Usage:
  1. Download OpenSCAD: If you haven't already, download and install OpenSCAD from https://openscad.org/downloads.html.
  2. Open the file: Open the provided OpenSCAD file (.scad) in OpenSCAD.
  3. Customize parameters: Adjust the parameter values in the code to modify the pendant's design.
  4. Render the model: Click the "Render" button to preview the pendant.
  5. Export the model: If you're satisfied with the design, export the model as an STL file for 3D printing.
3D Printing:
  1. Load the STL file: Load the exported STL file into your 3D printing software.
  2. Prepare for printing: Adjust the printing settings (e.g., layer height, infill density) as needed.
  3. Start the print: Begin the 3D printing process to create your personalized Viking pendant.
Enjoy your unique and customizable Viking pendant!
parametric design
3D printing
viking pendant
viking
pendant
customizable
unique
adjustable dimension
jewelry
unique gift
