2026-10-25 23:25:33
49
Phantom Hall – Haunted Halloween Manor
@drakeforge3d_5567152
Some houses have visitors. This one has spirits that never leave.
This haunted Halloween manor combines gothic architecture with ghosts emerging from its walls and rooftops. A large, wailing phantom stretches across the front above the entrance, while smaller spirits haunt the corners of the house.
Steep tiled roofs, pointed turrets, arched windows, detailed masonry, and curved entrance steps give the building its storybook horror character. The flowing ghost shapes contrast with the stonework, making the façade a striking focal point.
A spooky centrepiece for a Halloween village, seasonal shelf, or gothic display. Keep it in a single colour to showcase the architectural details, or paint the house and its spectral residents to bring your own haunting scene to life.
Designed for FDM printing with supports.
   Guide
1. DRY THE FILAMENT
  • Recommendations:
halloween
halloween manor
Haunted manor
halloween decor
decor
art
spooky
creepy
horror
