2026-09-03 18:59:53
316
9
Ping-Pong Ball Holder Dispenser | Minimalistic
@MarioMan_3779976
This time hold more balls conveniently, keep your place clean and organized while having easy access and fill up. Now I can hold many more balls while being able to just slip away and take up little space.
  • Holds many balls
  • Small footprint
  • Easy access
  • Easy refill
  • Minimalistic
Printing notices
Important this model doesn't have really tight tolerances but you must let it cool do not pull it of the plate or 5 minutes later it will warp and the balls will not pass through. I recommend waiting it at least 35 C or until it can slide right off with no issues. Don't rush this part. This has some hard over hangs that might not stick so if you have a newer printer I would recommend slowing it down. Also you might want to turn on avoid crossing walls. I would not run it all fast speed or even full speed depending on how confident you are in your printer. Please let me know if you need have any problems or encounter any issues I would be happy to help or even redesign it for your needs like less over hangs. Happy Printing!!
minimalistic
Holder
Ping pong
