2026-06-07 03:51:19
940
49
Pirate playset: patch - coin - hook - (foam)sword
@Together3D_3940323
Ahoy, matey! Ready to sail the seven seas looking for treasure? Whether you're gearing up for Halloween, a costume party, or just some epic backyard roleplay, this ultimate pirate playset has everything your little captain (or you!) needs to live the pirate life.
This set includes:
  • Pirate hook: with an easy screw mechanism connecting the hook to a handle, hidden under the cover.
  • Pirate coin: a detailed supportless printing coin with a skull on it.
  • You can print this coin 360° design (standing up) or with a flat back to glue together later - the last one prints considerably faster for giant treasure piles.
  • Eyepatch: just add elastic thread through the holes
  • This eyepatch is has 2 variants: with and without a pirate logo
  • The eyepatch is printed upwards to avoid print scarring, therefor I just pained my logo white to save filament
  • Sable: printed in 2 pieces, just push the blade in the handle.
  • The point of the sword is dulled down, for obvious reasons.
  • Foam sword: screw the handle into a piece of pool noodle to make your own (very safe) pirate sword.
  • This was designed for a pool noodle of 6 cm diameter and a hole of 1,5 cm.
The items are big enough so an adult can wear them as well. Allthough the fully 3D printed sable is more a big fancy (but very cool) dagger (about 35 cm tall).
I testprinted the hook at 75% and the screw system works perfectly, but that would be more for a toddler (max 5 years). Everything older I suggest the 100% version.
Assembly
Hook
Hold the hook part into place and screw in the bottom handle part, with the cover in between.
Foamsword
Screw in the handle into the pool noodle part.
I used a pool noodle of diameter 6 cm and a a hole opening of 1,5 cm.
The part I used was cut at 50 cm tall.
Sable
Push the sword part into the handle part, add a dab of glue in the opening. It is a tight fit, but it will need a bit of glue.
I wish you all many fun battles and treasure hunts!
pirate
pirate set
eyepatch
patch
sword
sable
foamsword
foam sword
coin
treasure
hook
dress up
costume
roleplay
pretend
skull
foam
pirates
gold
