2026-06-23 03:43:56
667
19
Pixel 10 Cover SlimLine
@PlaDreams_4057917
Improved buttons
Note: This is very slim, about 1mm thickness, so if you constantly drop your phone, maybe a stronger case is advisable.
Thanks to Bibiscus for the HD phone model
Like i said above, Pixel 10 and 10 Pro case/cover slimline.
Includes a USB cover too. You are sure to loose some, so printing 5 saves time.
The design is made on the slicer, and you can remove it by changing the "Bottom Surface" inside Strength tab.
Supports, shouldn't need if you use my profile.
Bridge :
  • Flow ration - 0.5
  • Speed - 15 mm/s
Strength:
  • 3 Walls
Quality:
  • Layer Height - 0.2
  • Seam - Random
Pixel 10
Pixel cover
slimline
phone cover
phone case
