2026-10-13 03:58:58
216
Plant Support Stake | Label & Clips
@MateuszTokarz_4351639
BOM: Printed with ROSA3D PLA Starter Light Blue
Are your young seedlings and herbs flopping over? This clever, multi-functional plant support is the perfect solution for any indoor gardener!
Designed for maximum utility, it features a sharp pointed tip that drives into packed soil effortlessly, alongside two integrated open clips that gently wrap around and support the stem vertically. At the very top, a flat leaf acts as a built-in label—just grab a marker and write down the plant's name (like "BASIL") or the planting date.
Key Features:
  • Integrated Label: The top leaf provides the perfect flat surface to label your plants or record dates.
  • Safe Stem Clips: Two rounded, open hooks keep flimsy stems upright without crushing their delicate structure.
  • Easy Insertion: The sharp bottom tip allows you to push the stake into dense potting soil without resistance.
  • Support-Free Design: The entire model prints perfectly flat on the build plate, saving you time and filament.
Printing Instructions:
  • Orientation: Print completely flat on the build surface.
  • Supports: NONE. The entire model is optimized to print without any support structures.
print
stem
plant
clip
planter
support
garden
grow
home
label
gardening
accessories
indoor
seedling
argiculture
herbs
stake
basil
