2026-03-13 11:38:55
1.5k
135
Polishing sandpaper holder
@Nexmesh_1625166
This print profile is optimized for producing a strong and precise Polishing Sandpaper Holder. The model is designed to print easily without supports and works well with standard 0.4 mm nozzle printers. Using a 0.2 mm layer height provides a good balance between print quality and speed while maintaining smooth surfaces for comfortable hand use.
The profile uses moderate infill and reinforced walls to ensure durability, especially around the threaded and clamping components that experience mechanical stress during sanding. PLA is recommended for easy printing, while PETG can be used if additional strength and wear resistance are required.
All parts are oriented for stable bed adhesion and clean thread printing, making assembly simple after printing. This profile is suitable for most FDM printers and is ideal for workshop tools, DIY projects, and functional prints.
Polishing sandpaper
holder
sandpaper holder
polishing
hanger
decor '
decorative
sanding tool
sanding block
