2026-06-24 13:34:10
1.5k
21
Power tower, expandable, semi-modular 动力塔 可扩展 半模块化
@YGG2Any_3251657
A scalable, semi-modular toy designed to demonstrate gear transmission.
Assembled size: approximately 250*100*100mm
The current kit includes 13 types of power transmissions.
Except for Layer A at the base, Layers B and C each have 4 types:
- Layer A has equal-ratio spur gears, 1:2, and 2:1 spur gears
- Layer B includes Scotch yoke mechanisms and variants, as well as piston-like connecting rods
- Layer C features Geneva mechanisms, incomplete gears, and ratchet gears
- The top layer is a planetary gear set
- Connections and power transfer in each layer are standardized and can be continuously expanded.
一款用于展示 齿轮传动的 可扩展 半模块化玩具
组装后尺寸 约 250*100*100mm
  • 当前组件包含13种动力传动
  • 除A首层外,BC都有4种
  • A层是等比平齿轮、1:2、2:1平齿轮
  • B层是苏格兰轭及变体,以及类活塞连杆
  • C层是日内瓦间歇机构、不完整齿轮、棘齿轮
  • 顶层是行星齿轮组
  • 每层的连接、和动力传输标准化,可持续扩展
Non-3D-printed parts include 3 608 bearings and 2 M2.5*10 screws.
非3D打印件包括 3个608轴承 、2个M2.5*10螺丝
Assembly illustration:
The internal power transmission is the same for each layer, only shown here once; the 4 sides are identical.
Inside the frame and some components, you’ll see markings like A1, A2, etc., for reference.
组装示意如下:
内部动力的传输 每层都一样,仅在此展示,4个面也是相同的
框架内侧和部分组件内侧 有A1、2等的记号标识 可参考
The longer 'horizontal axis' of layer A is different from BC, just a heads-up. The shorter one is the same.
A层的 较长的“横轴”和BC不同,请注意。短的是一样的。
玩具
可动玩具
齿轮
