2026-04-17 22:32:35
749
24
Precision Heat-Set Insert Station Pro
@Andy_5148966
Precision Heat-Set Insert Station for 3D Prints
Anyone deep into 3D printing knows the struggle: to create durable screw threads, you need to melt metal heat-set inserts into your plastic parts. Doing this by hand often leads to crooked threads and ruined parts.
This custom-built station solves that problem, turning a tricky task into a clean, professional, and repeatable process.
Key Features:
  • Perfect Alignment: The soldering iron is secured in a stable guide along the vertical aluminum extrusion. This ensures the insert is pressed into the plastic perfectly vertical every single time.
  • Adjustable Depth Control: Using the thumb screws on the back, you can set a precise depth stop. This prevents the insert from sinking too deep or damaging the opposite side of your part.
  • Integrated Heat Protection: The base features a 100x100x3 mm aluminum plate. If a hot insert accidentally drops, it won't melt into the station's housing.
  • Everything in Reach: The base includes a built-in drawer with 18 compartments. This allows you to store and organize various sizes of inserts (e.g., M2, M3, M4) right where you need them.
Why use it?
Instead of relying on a steady hand and guesswork, this station provides industrial-grade repeatability. It is the ultimate tool for makers looking to take the assembly quality of their 3D-printed projects to the next level.
Note: Technical specifications regarding compatible soldering iron diameters and the full Bill of Materials (BOM) can be found in the parts list below.
🛠 Bill of Materials (BOM)
🖨 Print Settings & Frame
  • Material:
  • PETG (highly recommended for better heat resistance).
  • Base Screws:
  • 5 x M3 Countersunk screws (min. 10 mm length).
🏗 Mechanics & Linear Guide
These components form the core vertical movement system:
1 x 3030 Aluminum Extrusion Length 440 mm+ (Amazon)
1 x MGN12-H Linear Rail Length 400 mm+ (Amazon)
2 x Tension Springs 8.5 x 47 mm (Amazon)
4 x M3 T-Nuts For 3030 Profile (Rail mounting) (Amazon)
4 x M6 T-Nuts For 3030 Profile (Depth stop) (Amazon)
🛠 Assembly & Hardware
Fasteners required to assemble the carriage and iron holder:
  • Soldering Iron Mount:
  • 4 x M3 Countersunk screws (16 mm) (Amazon)
  • Soldering Iron Clamp:
  • 1 x M4 x 25 Hex bolt (Amazon)
  • 1x M4 Nut (Amazon)
  • Depth Stop:
  • 2 x M6 x 16 Hex bolts (Amazon)
  • General Assembly:
  • 1 x M4 x 60 mm Screw (Amazon)
  • 6 x M3 x 12 mm Screws
  • 3 x M3 x 6 mm Screws
  • 8 x M3 Heat-Set Inserts (for the printed parts themselves) (Link)
  • 1 x M4 Heat-Set Insert
⚡ Tools & Accessories
  • Heat Protection:
  • 1 x Aluminum plate 100x100x3 mm (Amazon)
  • Soldering Iron:
  • 1 x Compatible Soldering Iron (Amazon)
  • Tips:
  • 1 x Set of Heat-Set Insert Tips (Amazon)
  • 1 x Set of M3 Screws (Amazon)
Printing:
Print the handele.stl in 45° so it fits to the 250x250 print plate
Print Slider-front.stl, slider-back.stl (and stand-top.stl if you want the textured surface on the top) with Support all others don't need Support.
brass
thermal
threaded
inserter
Precision
Heat-Set
Insert Station
