2026-10-25 21:14:44
48
PrintBlade X – 2-in-1 Scraper & Handle for Anycubic Kobra S1 / S1 Max
@Bnis_1720601
PrintBlade X – 2-in-1 Scraper & Printer Handle
One tool. Two functions. Designed for Anycubic Kobra S1 & S1 Max.
Meet PrintBlade X, a sporty, ergonomic 3D-printable tool that combines a build plate scraper with a convenient printer handle.
Designed to be practical, compact, and easy to print, PrintBlade X gives your scraper a dedicated place on your printer while keeping it ready whenever you need it.
  • 2-in-1 Design – Functions as both a print removal scraper and a convenient printer handle.
  • Designed for Anycubic Kobra S1 & S1 Max – Integrated mounting channel designed for these printers.
  • Ergonomic Grip – Comfortable shape for everyday use.
  • Smooth Scraper Edge – Designed for gently lifting prints from the build plate.
  • Sporty Design – Modern styling with distinctive PrintBlade X branding.
  • No Additional Hardware – No screws, magnets, or purchased components required.
  • Compact & Lightweight – Easy to print and convenient to keep on your printer.
Print Information
SpecificationValueFilament usageApprox. 22.15 gPrint timeApprox. 45 minutesRecommended nozzle0.4 mmMaterialPLA or PETGPrinter compatibilityAnycubic Kobra S1 / S1 Max
Print time and filament consumption are based on the tested print setup and may vary depending on your slicer settings.
How to Use
As a scraper: Use the smooth scraping edge to carefully lift completed prints from the build plate.
As a printer handle: Slide PrintBlade X onto the compatible printer handle using the integrated mounting channel, keeping the tool conveniently positioned for everyday use.
Important Notes
  • Check the fit on your printer before applying force.
  • Avoid using excessive pressure on the scraper edge.
  • Take care when removing prints from delicate build plate surfaces.
  • PETG may be preferable where additional toughness or temperature resistance is desired.
Designed for Makers
PrintBlade X was created to make everyday 3D printing a little more convenient.
A useful tool, a dedicated storage position, and a clean sporty appearance — all in one compact print.
Print it. Mount it. Use it.
If you enjoy PrintBlade X, please consider leaving a like, rating, or sharing your finished print!
Happy printing!
3D Printer
Scraper
Print Removal Tool
Ergonomic Handle
Build Plate Scraper
Printer Handle
Kobra S1 Max
Kobra S1
