2026-10-20 03:24:00
108
Pumpkin POOP Hallowen
@ElFranko_5863541
🎃 Halloween Pumpkin Poop Chute / Purge Bin for Anycubic Kobra 4
Bring some festive Halloween vibes to your 3D printing setup!
This is a functional and spooky Pumpkin Poop Chute (Purge Bin) designed specifically for the Anycubic Kobra (ACE Pro 2 system). It turns the boring process of filament purging into a fun holiday decoration.
The model consists of two parts:
  1. The Jack-o'-Lantern Shell: A detailed pumpkin cover with a spooky face that slides over the collection mechanism.
  2. The Functional Insert/Chute: The inner part that securely mounts onto your printer to catch all the filament "poops" cleanly.
⚙️ Features:
  • Perfect Fit: Designed to match the purge zone of the Anycubic Kobra 4
  • Easy Assembly: Two-part interlocking design – no glue or extra hardware required.
  • Holiday Spirit: The perfect functional upgrade for the spooky season.
  • Removable Cover: You can easily slide the pumpkin shell off if you want to clean or swap it.
🖨️ Recommended Print Settings:
  • Material: PLA (Orange for the pumpkin, Green for the stem, Black for the chute/eyes).
  • Layer Height: 0.2mm works great for smooth pumpkin curves.
  • Supports:
  • Pumpkin Shell: Minimal supports might be needed only under the main overhanging front arch (mouth area), depending on your printer's bridging performance.
  • Chute Insert: Print in the orientation shown in the files; standard support for the mounting peg recommended.
  • Infill: 10-15% (Grid or Gyroid).
Poop
Pumpkin
Hallowen
