2026-10-25 23:10:36
118
19
Pumpkin Wraith – Halloween Ghost
@drakeforge3d_5567152
Bring a sinister touch to your Halloween display with this ghost emerging from a shattered jack-o’-lantern. A curling crest, flowing spectral folds, and a wicked, tooth-filled grin give the spirit its menacing character, while the pumpkin beneath mirrors its terrifying expression.
The ghost’s sweeping arms grip the broken pumpkin rim, bringing the two figures together in one striking sculpture. Deep grooves, bold facial features, and dramatic curves make this piece stand out on a shelf, desk, or Halloween display.
Designed for FDM printing with supports. Display it in a single colour to highlight the sculpted details, or paint it to create your own haunted Halloween centrepiece.
   Guide
1. DRY THE FILAMENT
  • Recommendations:
halloween
halloween decor
Ghost
Halloween Ghost
Halloween Pumpkin
Spooky
Creepy
Decor
Art
Horror
