2026-04-16 07:01:27
6.5k
522
Purge Calibration Test Kobra X
@DKNSJCC_4234124
1 — Open the test file
Pick your printer/slicer file from your files, then:
  1. Open Anycubic Slicer Next
  2. Click Open Project
  3. Open the 3MF file into a new project
You will then see the loaded project with several plates (depending on the number of colors).
2 — Set colors and flushing values
If you opened the correct file for the Kobra X1, there are only a few settings you need to change.
Steps:
  1. Select the colors and filament you want to use
  2. Go to:
Filament Settings → Flushing / Purge Settings
There you will see the purge values between colors.
Important setting:
You want this to be:
  • Flushing volume: 50
  • Multiplier: 1.00
If it looks different (which usually happens after changing colors), you need to change all flushing values back to 50.
3 — Check infill directions
Before slicing, verify this setting.
Go to:
Print Settings → Infill
Find:
  • Sparse infill direction
  • Solid infill direction
Both must be 0
If they are not, change them to 0 degrees.
Print Settings → Quality
  • Print infill first enabled
This ensures consistent test results.
4 — Slice and print
Now you are ready to print the test.
Steps:
  1. Choose which plate you want to print:
  • 2 Colors
  • 3 Colors
  • 4 Colors
  1. Click that plate to select it
  2. Click:
SLICE
  1. Load your filament if you have not already
  2. Click:
PRINT
Or send the file to the printer and start the print.
5 — Expected result
Once printing finishes, you will have a strip with multiple transition blocks between colors.
Each block represents a different flushing amount.
6 — Reading the results
This is where you optimize filament usage.
Steps:
  1. Carefully remove the samples
  2. Place them on a white background (paper works fine)
  3. Look at each sample and find the point where the previous color fully disappears.
kobrax
purge
multicolor
test
calibration
