2025-03-03 13:41:06
2.6k
208
RC Off-road vehicles
@Makeronline_5218176
We wanted to print a large and exciting toy to test the printing and material performance of SIC. After many brainstormings, we decided to choose to build an RC off-road vehicle.
The model is divided into body and tires to adapt to the printing size on the SIC machine.
[Tools required]
MJX R/C 14209 Chassis
DJI Action connector
DJI Action Protective Frame
[Recommended printing parameters]
We recommend using ABS for printing the casing, choosing a printer with a closed box, and setting the printing temperature according to the recommended temperature value for the specific filament.
Using a layer height of 0.2 mm, 3 walls and an infill ratio of 30% should give good results.
[Important notes]
This model includes the design of the body and tires. In order to adapt to the off-road environment, the tires are suitable for sandy terrain. If you need to drive on cement roads, you can replace other types of tires.
If you want to achieve the effect of remote control, you can choose the 4G remote control car control module to transform your big toy.
We understand that there are many talented designers who can continuously optimize and remix the design to suit your preferences.
We welcome everyone to remix and improve upon this model. We hope you enjoy it!
我们想打印一个让人感到兴奋的大玩具去测试SIC的打印和材料性能,经过多次的头脑风暴,我们决定选择制造一辆RC越野车。
模型分为车身与轮胎,适应在SIC机器的打印尺寸,
[完成遥控车所需工具]
MJX R/C 14209底盘
DJI Action连接件
DJI Action保护框
[推荐打印参数]
我们建议使用ABS进行外壳的打印,选择封闭箱体的打印机,根据特定灯丝的推荐温度值设置打印温度。
使用 0.2 毫米的层高、3 层壁和 30% 的填充率应该会产生良好的效果。
[重要提示]
本模型包含车身和轮胎的设计,为了适应越野的环境,轮胎适合在沙地中形式,如需要在水泥路上驾驶可以更换其他类型轮胎。
如想达到远程遥控的效果,可选择实暻4G远程遥控车控制模块改造你的大玩具。
我们知道有很多才华横溢的设计师可以不断优化和重新混合设计以满足您的喜好。
我们欢迎大家重新组合和改进此模型。希望您喜欢它!
