2026-10-06 01:03:21
1.1k
117
Radius Gauge Tool
@VC_Design_4324288
The Radius Gauge Tool is a compact, closable case containing 30 inserts for checking both internal and external radii :)
Each insert features two gauges, allowing you to quickly check the radius of a part without needing separate tools.
The inserts are clearly marked with a code such as 23/8:
  • First number: internal radius gauge
  • Second number: external radius gauge
The complete set provides a convenient and organized way to check a wide range of radii, while the closable case keeps all inserts together.
  • 30 interchangeable radius gauge inserts
  • Checks both internal and external radii
  • Clearly labelled inserts
  • Compact, closable case
  • Prints without supports
Simple, secure, and reusable.
radius
tester
tool
gauge
internal
external
concave
convex
vcdesign
