2026-05-24 21:07:24
342
10
Rainbow Brick Maker - ¡Moldeador de Ladrillos de Arena y Nieve!
@Kracko1__964009
Take your beach or snow days to the next level! This design is the ultimate tool for building perfect castles, fortresses, and walls quickly and with super fun. Ideal for enjoying with kids (or unleashing your inner child!).
The model features a plunger mechanism with an ergonomic handle: fill the mold with damp sand (or snow), press to compact, push the handle down while lifting your body... and that's it! A perfect, solid brick in seconds, without breaking when demolding.
✨ Key Features
Perfect Demolding: Thanks to its integrated press/plunger system, the bricks come out intact and compact.
Ergonomic and Durable: Designed with a comfortable grip so even the youngest users can use it effortlessly.
Zero Supports: The model is geometrically optimized for clean printing without wasting material on supports.
Rainbow Effect: It looks spectacular when used with multi-color filament (Rainbow PLA/PETG)!
🛠️ Print Settings
To ensure it withstands intense use in the sand or snow, I recommend the following settings:
Recommended filament: PETG or ASA (they have better resistance to sun/UV rays and impacts), although a good quality PLA will work perfectly if you're not going to leave it in direct sunlight.
Layer height: 0.20 mm or 0.24 mm (to save time).
Walls (Perimeters): A minimum of 3 or 4 wall layers to give the handle and body a solid structure.
Infill: 15% - 20% (Gyroid or grid to withstand the pressure when compacting the sand).
Supports: NO (Make sure to place the pieces flat on the print bed in the correct orientation).
📦 What's included in the file?
Mold body: The outer rectangular box.
Press / Plunger: The inner piece with the handle that pushes the brick out.
game
construction
beach
snow
sand
children
anycubic
bambulab
elegoo
creality
