2026-07-09 06:21:08
536
41
Rebel A-Wing Starfighter from Star Wars Replica
@dharian_5531540
Outrun the Empire and add the fastest interceptor in the Rebel fleet straight to your desktop!
This is a highly detailed, 3D-printable scale model of the RZ-1 A-wing interceptor, famously known for its role in the Battle of Endor in Star Wars: Return of the Jedi. This model perfectly captures the starfighter's iconic arrowhead silhouette, its twin rear J-77 Eventide engines, dual pivoting wing-mounted laser cannons, and the sleek central cockpit.
This version has been specifically engineered for single-color printing. You don’t need an AMS, multi-material unit, or complex filament-swapping systems to get an incredible result. Instead, the model utilizes deep, pronounced panel lines, crisp cockpit framing, and sharp geometric transitions that rely on natural shadows and room lighting to make the features pop sharply. It has been tolerance-tested on Anycubic FDM printers (such as the Kobra, Vyper, or Mega series) to ensure clean layer execution across its smooth, sloped hull armor.
Model Features
  • Anycubic Slicer Calibrated: Optimized to handle the retraction paths between the main fuselage, the dual stabilizer fins, and the side laser cannons without causing excessive stringing or blobs.
  • Sleek Aerodynamic Silhouette: Captures the classic Rebel aesthetic, making it a perfect standalone display piece or an awesome addition to a Star Wars diorama.
Recommended Print Settings
  • Layer Height: 0.12mm to 0.16mm is highly recommended to cleanly capture the smooth sloped nose, the engine ridges, and the fine frames of the cockpit canopy.
  • Infill: 10% - 15% (Gyroid or Grid provides excellent internal stability without adding unnecessary weight to the rear engines).
  • Supports: Yes, supports are required under the main belly of the ship, the overhanging wings, and the side cannons. Tree/Organic supports configured in your preferred slicer (Anycubic Next, Cura, or PrusaSlicer) are highly recommended for clean, painless removal.
  • Brim: A 5mm outer brim is recommended to keep the support structures and the trailing edge stabilizers firmly stuck to your Anycubic print bed.
StarWars
AWing
RebelAlliance
Starfighter
Spaceship
Miniature
Replica
Vehicle
SciFi
Geek
DeskToy
3DPrint
Model
Movie
PopCulture
EasyPrint
