2026-10-11 20:21:23
187
10
Retraction and flow test
@A3DBambus_3366497
This 3D-printable model is designed to test and calibrate retraction settings and filament flow rate. It consists of a flat square base with multiple vertical towers of different heights and positions.
The model helps identify stringing between towers, inconsistent extrusion, and excessive or insufficient filament flow. It can be used to fine-tune retraction distance, retraction speed, and flow rate to achieve cleaner prints, smoother surfaces, and more accurate extrusion.
retraction
flow
tets
